1st post and Working on a Ciao Piaggio vespa
. Become a Supporting Member to hide the ad above & support a small business
Sammydeconinck Avatar
Sammydeconinck Tony Leirens
Oudenaarde / Eine, oost-vlaanderen, Belgium   BEL
Sign in to contact
Already tried to help with start pilote before pedalling ?
Was this post helpful or interesting?
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
In reply to # 2945 by Sammydeconinck Already tried to help with start pilote before pedalling ?
I guess i don't understand...grinning smiley
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Well, i finally got smart and did a compression test this morning... 60 PSI Maximum.. I made sure the decompressor valve was fully closing too, and i hear no air leaks around the head gasket. So it's gotta be getting by the piston. Guess the cylinder wasn't as good as it looked.
i know 2 stroke chainsaws need at least 95-100 PSI to fire... so i assume its the same on here.
Yes No Thank
Sign in to contact
Hi, The best you can do is change the cylinder and setting the pistonrings with the right clearance in the cylinder....
Yes No Thank
  TCM3 thanked Sammydeconinck for this post
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
That's what I figured... MopedDivision has a cylinder kit for it I can buy for $105.00 usd.
Thanks tony!thumbs up
Yes No Thank
Sign in to contact
Travis , let me know when it's fitted !
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Will do!
I had to contact my brother in law to be sure the price was ok, haven't heard back yet.
Also dealing with the loss of a pet now.
smiling smiley
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
got the cylinder kit in from Moped Division today, pulled the engine and replaced the cylinder,piston and rings , gaskets. the motor feels much better turning over by hand...
Now to set the motor back into the frame!thumbs up
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Still wont start, compression is good now, spark is good and blue, its getting fuel....
Edit: my dad came out and helped me , he got it narrowed down to fuel mixture, it fired a few times...... anyone know how many turns out the speed screw is supposed to be?
Edited 1 time(s). Last edit at 2020-08-05 08:23 PM by TCM3.
Yes No Thank
Sign in to contact
Hi , what do you mean by speed screw ? picture ?
Yes No Thank
about 2 weeks and 4 days later...
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
sorry it took me so long to get back to you,. the screw i am referring to is just below the fuel fitting in this picture with the spring on it..... It's really more of an minimum idle adjuster.
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
I don't know what to do with this demon of a bike.....
I ordered a new airbox due to the old one being cracked around where it clamps to the carburetor, fits good.... but it wont fire, to me it really smells like its rich, but the other day a test we did by placing paper towels over the intake to block out excess air and it fired up for a bit, which that made me think it was running lean to start with, but after peddling for a few seconds, i smell gas which makes me think its running too rich, yet the symptoms say it's running too lean to even start.... i guess i may replace the crank seal next as i ordered a new one.
Edited 1 time(s). Last edit at 2020-08-24 04:17 PM by TCM3.
Yes No Thank
Sign in to contact
Hello, the screw you mean is the idle screw. turn it in to the moment that the throttle goes in movement + a little bit more +/- a third of a turn. The moment the motor runs, change the rpm's by adjusting this screw.....in= more rpm's....
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
the only problem is that is the only the screw on the carb.
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Well, i think i'll go ahead and replace that crank seal. If it put starting fluid straight into the cylinder it will puff puff, like it's very lean. We'll see....
Yes No Thank
To reply or ask your own question:
or
Registration is FREE and takes less than a minute
Read the Forum Help (FAQ) or click Contact Support at the bottom of the page.
1965 Vespa 150 Sprint
