1st post and Working on a Ciao Piaggio vespa
. Become a Supporting Member to hide the ad above & support a small business
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
OH MY LORD........................
can't get the flywheel off! tried the method we used the first time. no dice.
Also, does anyone know what thread the nut and crank end are? the threads are folded over a bit,not very bady and i need to rethread them.
Was this post helpful or interesting?
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Well, i think i'm going to resort to an air hammer to try and vibrate it off.... IT'S LOCKED ON THERE TIIIIIIGGGHHHHTTTT!
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Okay, well the flywheel wouldn't come off for nothing, not with the puller, not while holding the engine up by the flywheel, and hitting the nut on the crank end like did the first time. the crank end just imploded on itself..
Bought a rebuilt motor for it, it runs pretty good at high RPM, but wont idle worth a dang. Toyed with screw positions for 30 minutes, it does seem to idle a lot better about half choked, that's after cleaning the carburetor too.
The carb was a cheap chinese copy, so im wondering if it may have the wrong size jet in it.... not sure what to do.
Yes No Thank
Sammydeconinck Avatar
Sammydeconinck Tony Leirens
Oudenaarde / Eine, oost-vlaanderen, Belgium   BEL
Sign in to contact
HiTravis , best thing you can do,is getting a flywheel puller with M17 x 1 mm. Throw that shitty chinese carburator out , and get a Dell'orto for it....if it is a 25km/h take a 12 mm. If its a 45km/h version place a 13mm.
At your service , Tony
Yes No Thank
Sign in to contact
hello again, the type Dell'orto carb you need, is an SHA type....
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Thanks tony! Looking up a Dellorto carb right now.
Yes No Thank
Sign in to contact
You don't have the original carb anymore ?
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
No, the casting that holds the float pin cracked in two pieces.
Yes No Thank
Sign in to contact
Hi travis , is the carb. type not marked on the old one ? Pleases,give me thr frame number of the moped...
Wkr, Tony
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
No, i don't see it marked anywhere, on either... I will get you the frame number.
also, here is the cheap chinese one i bought several months ago to replace the orginal https://www.ebay.com/itm/Carburetor-Carb-For-PIAGGIO-Ciao-PX-FL-VESPA-moped-pocket-SHA-12-12-DELLORTO/163875628618?hash=item2627bfa64a:g:LicAAOSwZuFdjYUF
Yes No Thank
about 1 week and 3 days later...
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
Got the Brand new O.E.M Dellorto carb in the mail, got it put on, but i'm going to wait till morning to try and start it, I'm sleepy yawning smiley
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
That's it.. I'm done with this piece of crap. Won't even fire off this morning. Choke, no choke, starting fluid, cleaned and gapped spark plug again, unplugged the coil kill wire so it's just the points wire hooked to it. my spark tester shows good, strong blue spark. and the spark plug smells a little bit like fuel, not like it's flooding though.
I give up.
Yes No Thank
Sign in to contact
Hoi Travis,
You can have moments that all things goes wrong , but NEVER give up ! My idea is that the fuel is stucked somewhere or is not passing true.....Check systematically all you can.
i'M sure you find the solution !
Patience , Tony.
Yes No Thank
TCM3 Avatar
TCM3 Travis M
Conroe, TX, USA   USA
Sign in to contact
I've been patient with this thing for 5 months,
i removed the carb and turned it upside down, and fuel flows out of the venturi tube hole where it's supposed to come out.
I know i have Fuel, I know i have spark at the plug, i know i have compression, and the ignition timing is also correct.
Yes No Thank
Sign in to contact
Travis, you are sure that the woodruf key behind the flywheel is intact or on his place ? Can you post a video to tony.leirens@gmail.com ???? Best while pedalling and with noise ....I wait on an answer , to help you.
Greets , Tony.
Yes No Thank
To reply or ask your own question:
or
Registration is FREE and takes less than a minute
Read the Forum Help (FAQ) or click Contact Support at the bottom of the page.
1961 Lambretta TV 175 Series II
