Layshaft oil leak
Sidecardriver Richard Placak
Atascadero, CA, USA   USA
What seals the left side of the layshaft on a VBB? I have a leak and I don't see any seal in the manuals.
Hello Richard,
Yes there is a left side seal piaggio part number 46699 Rear Hub 27 x 37 x 7
16.jpg    45.3 KB
Thanks Matthew but that is the seal on the transmission output shaft. My leak is where the layshaft (counter shaft) comes through the case at about 5 o'clock in relation to the clutch cover. That shaft doesn't turn, the gears turn on the shaft. There is a nut on the end of the shaft with a lock washer with bent up tabs. It may be that the shaft is an inference fit with no seal and the case is warn and does not seal. I don't know what would happen if I removed that nut and attempt to put an o ring on the end of the shaft. I think the case would need to be opened up to work on that shaft.
Hello Richard,
I think you are referring to the spring gear assembly which I do not think they had o-rings on the pin.
Here is a link to the spare parts manual compliments of scooterhelp
http://www.scooterhelp.com/serial/VBB.parts.book.html
18.jpg    44.1 KB
Yes I think that's where the oil is coming from. I reduced the amount of oil in the gear box and that helped some.
2009 Vespa GTV 250 60th Anniversary
