The Body.
Although it's all intact and at a brief glance looks presentable there are lots of extra holes, bent and torn sections and rough repairs by brazing over the top of twisted/dented panels. The use of bronze as a repair medium is a real PITA if you want to do things correctly as any attempt to weld over the bronze area (even if most of it has been ground-off) causes the repair area to spit back and flare as the bronze through capilliary action bonds with the parent steel being repaired. All these areas then need to be cut-out and replaced with fresh steel. Then the bugbear is to limit any panel warpage. The section on the front panel will require quite a lot of fettling with the 'hot-torch' and cutting disc to regain correct symmetry.
The Vespa as presented.
Edited 2 time(s). Last edit at 2019-02-02 05:04 PM by enigmas.
